hounddog05
- Ohio
when is it required to use gnding lugs for bonding. For instance a lot of my work is 24x24 Hoffmann enclosures with 2-3" EMT without KOs. These are usually only used as J-boxes and I find myself wanting to use ground lugs and two hole mechanical lugs through bolted to the enclosure. Is this necessary to do all this bonding or does it depend on size of conduit, grounding electrode size, concentric vs eccentric KOs, etc? Thanks.
