Would the wire be within 1.25" from the outer finished surface of the roof?
What about mc? 12/3 when you can. Or would that be too visible?thanks for your responses , was planning to use #12 uf in a carflex for protection , the heat was my main concern too , did research on the tiles , & the roof is 40 % cooler than your normal roof , but this is texas & it gets really hot , but it would seem that this would still be as hot as a hot attic , the only problem i saw with running the conduit was there would not be room for connectors to run into the box , it would be more of a protective covering .
is it permissable to run electrical wiring between the roof & spanish tile roofing material with air gap in between , roof & tile , this has been asked in
order to conceal wiring for gazebo , thanks
I don't see why not
Agreed. But how are you complying with 300.11(A)(2)?
300.11 (a-2)
Does that apply to a wood framed gazebo
How is that relevant? Are you saying that we cannot run conduit in ceilings support by structural members?
