working on replacing in ground residential pool pump, 230 volt, GFCi protected, 1 HP. Existing pump had been in service for approx. 20 years and was operational (except for bad bearings)
The existing pump was bonded through the branch circuit conductor and customer says no problem over the years. I installed a 5/8 x 8 ground rod, reconnected new pump. Pump will work fine until the # 8 bond wire from the pump is connected to the rod which than trips breaker. Resistance reading from branch circuit egc and from # 8 wire ground to new pump to ground rod is 1500 ohms. and infinity reading from power conductors in branch circuit as well as wiring going to pump and branch circuit EGC. What am I not seeing that is causing the GFCI to trip?
