liquidtite
- Ny
I have four 1"" met conduits on a rack that will be offsetting 25" .
i bent the conduits using 45' angles
the spacing from center to center is 2" .
So my space in between bends was 35 3/8"
I made my first mark 33" from end of pipe to nAke the nose end up to land on rack and then made my second mark 35 3/8 " from that mark .
i bent each mArk at 45' and had my first piece .
Here's the part were not shure if I did correct my four conduits look good but the spacing is slightly off .
i know I have to add 3/4 "to my next piece but wasn't shure if I add it to both marks or just my second mark .
i ended up adding 3/4 " just to my second mark it got me close enough but want to see if I was correct .
i know there's a easier way we're u can line up spacing on floor and cut them all at shortest one
but I had extra time and wanted to try the diff method.
next ? Is after the 4 1" conduits I have to work a 2" next to them and then I'll have anouther
1" after the 2" suddenly the radious of the 2" is diff from the 1" what's the best way to fit the 1"
in . I was thinking I' could use last mum that I had for the 1" and try n cut it in
Thanks for your time
