K8MHZ
- Electrician
As we all know, the only way to test both GFCI and AFCI devices is by using the test button.
Having knowledge of the internal workings of a GFCI, I can see how pressing the test button creates an electrical imbalance through a CT by partially bypassing it. The CT detects resultant current and the device is electrically activated. The test button function is pretty close duplicating to any real world possibilities that exist.
I haven't torn an AFCI apart. I want to know if pushing the button is just a mechanical activation, or does the button create a type of a spark that the internal components 'see' and the device electrically shuts down, as the above?
Or does it simply supply voltage to an IC that has one pin set to trip when it sees that voltage, and that pin has no other function?
Inquiring minds want to know.
Thanks
Thanks
