PhantomElectric
- Owensboro, KY, USA
ok, first this is my first time posting and it's nice to meet you all.
quick background. electrician since 2000 , current own and operate an electrical contracting business and a tech company. primarily residential work with some light commercial.
a customer of ours had an arc fault breaker dead shorting (melodramatic as arc faults dead short). we are currently on the 2014 code, but the house was built 2 years ago when we were on the 2011 code. all 15 amp circuits are arc fault with the dining being the sole 20a arc fault. went to change the breaker out and noticed it was soaked. shut off the main and started pulling breakers in the 200a square d homeline panel. these breakers are the pigtails since it was put in prior to the homelines going to full length neutral bars. about 90% of the arc faults in the panel were soaked, none of the other breakers. it's like they are producing water. panel is in a storage room of a walk out basement, on a stud wall, open drywall, with 1/4" between the panel and the concrete wall. 15a breakers on the right were mostly all soaked and the sole 20a on the left side of panel was the only thing wet on that side.
so let's get the obvious out of the way. there is zero water coming from the mains, any wires leading into the panel, there are no water marks around the bottom or back or top of panel. there are no plumbing pipes within 10 feet of panel and the room, while not heated and cooled, stays a pretty constant temperature as the basement great room next to it. water is absolutely, 100%, without a shadow of a doubt leaking, penetrating, siphoning, leeching, dripping, spraying on the panel. at first i thought condensation, but that would be backwards. cold things get wet in hot weather, not warmer things getting wet in colder weather. the rest of the panel, excluding the arc faults, is completely dry down to the cobwebs and drywall dust. the bottom, top and back of panel is dry.
i have emailed square d tonight and should hear from them tomorrow; if not i'll just call at lunch. wanted to see if anyone here has seen this or has an answer. saw another 2012 post on here with the same problem also 2 years in. it was a dead post and saw no advantage to not making a new one. that guy got brushed off with jokes like he was just not catching a water leak or put in wet breakers to begin with. anyway, thanks ahead of time for any help.
