Strapping UF cable
packerbacker
WI
Was curious if someone could cite the code in the NEC that explains how far apart straps need to be on UF cable. I realized it sends you to 334, but I know it needs to be strapped closer than four and a half feet intervals. thanks in advance
iwire
Massachusetts
What about an Ag building? I was told hammer handle lenghth by Iowa state inspector
As far as the NEC goes 4-1/2' max between supports. Now that area may have amendments but I doubt it is 'hammer length'.;)
Now that said, the inspector might be able to put it to you this way:
'Either strap it like I ask or I fail it based on 300.4 and you use a different wiring method.'
