cpinetree
- SW Florida
Is a metal mast bonded to the building steel with its mounting hardware?
A metal mast is being installed on a metal building 80' from the service entrance.
The mast will have a wifi access point on the top.
The only power going up the mast is POE.
The main mounting brackets for the mast will be bolted to the structural steel.
We plan to drive a ground rod and use a clamp at the base of the mast.
Is that sufficient?
Do we need to run a bond wire back to the main service?
Do we need to run a bond wire to the structural steel at the mast location?
Is that sufficient?
