Stevenfyeager
- United States, Indiana
- electrical contractor
A customer who is selling his 50 yr old house wants me to correct everything so a home inspector will pass it. His meter is grounded to a ground rod, which feeds the house panel 20 feet away inside with 3 wires. The house panel has no ground wire going to a rod or to anything. There is no outside disconnect. This work was done probably 30 years ago. Also, there is a simple pull out 60 amp disconnect fed from the meter going to an out building. What will not pass an inspection here?
Thank you.
Thank you.
