Hello jwnagy, just a couple of questions. In the first post you wrote
Quote:
Originally Posted by jwnagy
I shut down the main breaker outside and all of the branch circuit breakers inside and checked continuity between ground and neutral in the sub-panel. I had no continuity until I turned a branch circuit breaker on. I checked continuity at the main, in the meter stack, and found continuity.
I wonder how, by turning on a breaker, continuity was obtained at the sub panel between the ground and neutral when no continuity existed prior?
The following is from another post:
EricKench,
The subpanel has a grounding electrode conductor between the ground bar and main waterpipe providing a path. I believe that whatever cut the neutral wire was also in contact with the ground wire.
Anyone please correct me if I'm wrong but in this case wouldn't the conductor going to the waterpipe be considered a bonding jumper and not a gec for we are speaking of a sub panel here.
