Go Back   Mike Holt's Forum > Lighting
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 10-29-2009, 05:37 PM
ultramegabob's Avatar
ultramegabob ultramegabob is offline
Default I want to learn about neon
I would like to learn about troubleshooting and repairing neon, what are some good sources for this subject? books, classes, websites? thanks!
__________________
THIS SPACE FOR RENT
  #2
Old 10-29-2009, 05:42 PM
augie47's Avatar
augie47 augie47 is online now
Default
Seems like that might be akin to wanting to be a dinosaur doctor
In these parts neon is quickly becoming:
http://www.ledneonflex.com/
__________________
Gus I won't say I'm from the dinosaur days, but my journeyman's test covered knob & tube wiring:-)
  #3
Old 10-29-2009, 05:56 PM
Default
there is still quite a bit of neon in my area that people want maintained, and there is only one sign company in my area that works on it and they have made alot of people mad so they call the other closest company that works on neon which is 50 miles away. Today I checked some neon ballasts for line voltage, but I dont have any way to check the load side, I tested the tubes with a gas tube tester and think I found the bad tubes, but I still dont know for a fact that the ballasts are good. and I dont even know for a fact that the ballasts are the correct size in the first place, I just want to know more about it....
__________________
THIS SPACE FOR RENT
  #4
Old 10-30-2009, 11:09 AM
MarkyMarkNC's Avatar
MarkyMarkNC MarkyMarkNC is offline
Default
If you are going to be repairing neon lighting, you're going to have to find a good neon glass bending guy anyway. Go in and talk to them. Grill them for all the information you can get out of them. That's pretty much how I learned how to repair neon signs.
__________________
62.584361% of all statistics are made up on the spot
  #5
Old 10-30-2009, 11:36 AM
Cavie's Avatar
Cavie Cavie is offline
Default
Transformer sizes are based on glass diamiter and total lenght of the glass. Just like wire and total load. YOu can get a quick referance book from a neon sign shop. I have forgotten most of it that I used to know. Voltage input/output is listed on the transformer. They either work or they don't. if glass is broken, you simply jump out the broken piece and the rest will work and take the broken piece to get it repaired.
__________________
Unlimited Electric Contractor/Standard Electric Inspector/Wind Mitigation Inspector/Highway Lighting and Signal Installer.
I know you believe that you understand what you think I said but I'm sure you realize that what you heard is not what I meant.
  #6
Old 10-30-2009, 01:26 PM
wireguru wireguru is offline
Default
LED is the big fad right now (like lumenyte and other fiber optic products in the early to mid 90s) but I think (and hope) neon is here to stay. It has a certain look that nothing else can recreate.
  #7
Old 11-05-2009, 11:02 AM
dbaird dbaird is offline
Default Reply
here is some free info:
http://www.epanorama.net/links/lights.html#neon
  #8
Old 11-05-2009, 02:11 PM
Default
dbaird- thanks for the link...
I just went on another service call yesterday that involved neon, a section of neon was damaged when the EIFS/Dryvit was being repaired, sadly it was only a small section on the end of the side of a building where is really wasnt noticeable and the customer elected to just remove the section and disconnect the transformer for now, I also pulled the leads to the neon tube and caulked the holes in the building shut. But as far as being a Dino-Dr. this is two related service calls in as many weeks....
__________________
THIS SPACE FOR RENT
  #9
Old 11-05-2009, 03:07 PM
Pierre C Belarge's Avatar
Pierre C Belarge Pierre C Belarge is offline
Default
Quote:
Originally Posted by dbaird View Post
This is quite the link!
__________________
Instructor, Industry Advocate
  #10
Old 11-07-2009, 01:53 AM
brantmacga brantmacga is offline
Default
neon isn't going anywhere. think about how many neon signs are in your city; when they go down, are the owners going replace the entire sign or fix what's broken? anyone ever priced out a new electric sign? its not financially feasible to replace an entire sign because of a bad tube.
__________________
Brought to you by Carl's Jr. ©
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
