Go Back   Mike Holt's Forum > Low Voltage and Limited Energy
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-05-2009, 08:13 PM
adam schweitzer adam schweitzer is offline
Junior Member
Default Generators
Why is it when I plug a tool into my 3000w generator it works fine but when I plug it into my 5000w generator it doesn't get up to full speed? It's a cutting tool and it doesn't happen with all tools.
  #2
Old 11-05-2009, 08:22 PM
iwire's Avatar
iwire iwire is offline
Default
First thing I would do is break out a true RMS meter and check both the voltage and frequency of the 5000 watt unit.
I bet your not even close to 60 cycles.
__________________
Bob
  #3
Old 11-07-2009, 04:17 AM
SG-1's Avatar
SG-1 SG-1 is offline
Default
It may have a control unit that idles it back if no load is present. The load that the cutting tool is presenting to the 5KW generator may not be enough for it to recognize. More load may be required for proper operation.
  #4
Old 11-09-2009, 10:16 AM
techntrek techntrek is offline
Default
Quote:
+1, although you'd think a "cutting tool" would be large enough. But the "cutting tool" could be a Dremel...
Try adding a 60w incandescent bulb, or a small electric heater. That should "wake it up".
  #5
Old 11-11-2009, 10:30 PM
Junior Member
Default
When it's plugged in, I turn the idol off of automatic so it doesn't idol and it still isn't working like it should. It's just weird that it works on the other smaller generators just fine.
  #6
Old 11-12-2009, 12:18 AM
SG-1's Avatar
Default
Quote:
I suppose it could be the type of motor used for the cutting tool is causing that particular regulator problems.
Tried the light bulb/heater suggestion by techntrek yet ?
  #7
Old 11-12-2009, 12:41 AM
nakulak's Avatar
nakulak nakulak is offline
Default
maybe your bigger generator is a piece of crap ?
__________________
"Better to remain silent and be thought a fool than to speak out and remove all doubt." - Abraham Lincoln
  #8
Old 11-12-2009, 01:42 AM
hurk27 hurk27 is offline
Default
Is the generator a inverter output?
If so it is because it puts out a modified sign wave, and brush motors will run much slower.
I had a Honda, that had this feature.
They are design to run electronic loads, not motors
__________________
Wayne A. From: N.W.Indiana
Be Fair, Be Safe
Just don't be fairly safe
Reply
101 Rules Forums
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
