Go Back   Mike Holt's Forum > Electrical Contracting and Estimating/Management
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Display Modes
  #1
Old 11-06-2009, 08:53 PM
nafis nafis is offline
Default electric stove
Hi Guys,
I am looking to purchase an electric stove for a customer of mine. He wants to install in a
guest house which has a sub panel 30 amps single barker in the entire guest house. Is
there any stove that works on a 120 volt with minimum amp, if so where I can purchase it.
Thanks
Nafis
__________________
Hypocrisy is annoying but not evil. someone who says one thing and does another has doubled their chances of being half right .
  #2
Old 11-06-2009, 08:56 PM
augie47's Avatar
augie47 augie47 is online now
Default
I think there are some "Barbie" stoves that work with a 100 watt lamp
the menu might be a bit more limited than your customer desires.
__________________
Gus I won't say I'm from the dinosaur days, but my journeyman's test covered knob & tube wiring:-)
  #3
Old 11-06-2009, 09:14 PM
bradleyelectric's Avatar
bradleyelectric bradleyelectric is offline
Default
The only 120v low amp ranges I know of connect to a propane tank.
__________________
Near Baltimore, MD
  #4
Old 11-06-2009, 09:17 PM
Cold Fusion Cold Fusion is offline
Default
Quote:
Originally Posted by nafis View Post
... Is there any stove that works on a 120 volt with minimum amp, if so where I can purchase it. ...
As brad suggested, apartment sized (24") gas stove with an outside propane bottle. That's what I put in my cabin. Works great. I could get it with either a plug-in electric ignitor or a piezo(sp) ignitor.
I'm assuming you don't want a two burner hot plate and a microwave.
cf
__________________
Day job is a PE. Preference is to not be in the office
  #5
Old 11-06-2009, 09:29 PM
JFletcher JFletcher is offline
Default
A one or two burner hot plate is about all you can run for an "electric stove" on a 120V service with such little capacity.
  #6
Old 11-06-2009, 09:35 PM
Default
I didn't see Cold Fusion's post. Good ideas. And yes, it is spelt "piezo".
  #7
Old 11-07-2009, 12:31 AM
Cavie's Avatar
Cavie Cavie is offline
Default
__________________
Unlimited Electric Contractor/Standard Electric Inspector/Wind Mitigation Inspector/Highway Lighting and Signal Installer.
I know you believe that you understand what you think I said but I'm sure you realize that what you heard is not what I meant.
  #8
Old 11-07-2009, 05:51 AM
LarryFine's Avatar
LarryFine LarryFine is offline
Default
A hot plate and a toaster-oven would be the closest to a range in function.
__________________
Code references based on 2005 NEC
Larry B. Fine
Master Electrician
Electrical Contractor
Richmond, VA
  #9
Old 11-07-2009, 03:10 PM
Default
thank you all for your help.
__________________
Reply
Motor Controls Forums
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
