temp. rating
jumathum
I have XHHW-2 type wire that per the NEC is rated at 90 degrees. Does the breaker that I am landing this wire to also need to be rated at 90 degrees to use the 90 degree ampacity?
Volta
Columbus, Ohio
Yes. 110.14(C) This will include the breaker, load equipment, lugs, splices, bushings, everything in the length of that conductor.
bob
Alabama
Yes. You may use the 90C rating for derating the conductor or temperature adjustments.
jim dungar
Wisconsin
PE (Retired) - Power Systems
Be aware, there are no UL listed breakers or fusible switches that can be used with the 90?C ampacities. Even though some equipment requires 90?C insulation the conductors must be sized at least as large as required under thee 75?C column.
Smart $
Esteemed Member
Ohio
"SQD has a good PDF in their site, that explains this very well."
A clip from said document....
Link to document: http://ecatalog.squared.com/pubs/Electrical Distribution/0110DB9901R2-02.pdf
Rockyd
Nevada
Retired after 40 years as an electrician.
Where would 90'C be a typical installation in the wiring methods under 600 volts? I can see using the column for the derate, but thought most 90 degree equipment was for over 600 volt for typical installation (providing it is rated for the activity)(110.40)
Smart $
Esteemed Member
Ohio
No such thing as a typical 90?C-rated installation under 600 volts, that I'm aware of.
