Alwayslearningelec
- NJ
- Estimator
How are they installed and what is a Bolson Chair? Thanks. Guys I like asking questions on here because I think the best information comes from the electrician.
Can we assume that it's a chair that rides up a rail, in a stair well?
I would consider this a 21st century bosun's chair (replace the leg loops with the rigid batten seat). You can pretty much sit in it all day while working in a shaft. Find an adequate tie in point at the top of the shaft and lower yourself down with a climbing rope. Use a fall arrest rope as a backup connected to the top D ring of the shoulder suspenders. I use a similar saddle for tree work without the suspender.
Still warrants being careful.
http://www.jems.com/article/patient-care/dangerous-suspension-understan
Christ Bob, do you normally read JEMS?? Where do you find the time?
