- Massachusetts
Proper name is autotransformerAlthough they're called buck boost transformers to begin with, I've always felt once you've decided what your going to do with it, it should be called by it's proper name not both.
With that being said, sell them on the "Boost" transformer,,,,, it will heat up quicker.
JAP>
Good man!Proper name is autotransformer
At least it wasn't a coffee maker. Coffee maker people get really wigged out if things are not just so......A customer bought a new Panini press
I say sell them on the buck and boost since it will heat up faster.
Good man!
But I'm just a foreigner..........I bet if I called my supply house and asked for an autotransformer they would tell me to call an auto parts warehouse.
I can't speak for any other area but around here buck boost is the term to use if you want to be understood. If you want to look up the rules in the NEC that is when you need to know they are autotransformers.
I was impressed that the press is UL listed.
