What size equipment grounding conductor?
fbhwt
Electrical Systems Inspector
Spotsylvania,Virginia
I am in dispute over the size equipment grounding conductor needed. Service is 1000a ,208v, 3ph
3 sets of 4-400mcm from 1000a service disconnect to 1000a transfer switch. I say it should be 2/0 copper or 4/0 alu according to 250.122, disconnect is fused at 1000a
ibew441dc
It sounds like you got it down.....but just remember the EGC has to be full size in each of the raceways in parallel.
fbhwt
I was told I was not looking in the right place, something about 250.66, which we know is for sizing grounding electrode conductor.
ibew441dc
The short answer for you to back your self up(because you are correct) is to take a look at 250.102(C) and (d)
charlie b
Lockport, IL
Retired Electrical Engineer
Once you are beyond the service disconnecting means, table 250.66 is no longer a player. I agree with the others: you had it right.
