Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Magnetic fish tape
  1. #1
    Magnetic fish tape
  2. #2
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    I may be wrong but it seems to me if the wall was clear enough to have this work that you could snake it pretty easily with a steel tape.
    Imagine wood lathe, metal lath, insulation, etc. in the wall and I think that tool gets stuck.
  3. #3
    Join Date
    Mar 2008
    Indiana
    Posts
    2,547
    looks like a good way to get grey rub marks all over the wall, i would cover it with fabric or somthing if I was using it.
  4. #4
    Join Date
    Mar 2008
    Indiana
    Posts
    2,547
    I have used jack chain for dropping down in walls, gravity pulls it down, and you can make a hook out of a coat hanger to pull it over to your box opening.
  5. #5
    Join Date
    Sep 2004
    Durham, NC
    Posts
    5,500
    Protection of painted and various finishs was the first thing that came to mind. I guess it could be used through plastic, wax paper, or with a cloth wrapper.
    If you are even thirsty, you are two quarts low.
  6. #6
    Quote Originally Posted by iwire
    It claims to work in walls with insulation.
  7. #7
    Join Date
    Mar 2008
    Indiana
    Posts
    2,547
    Quote Originally Posted by Rawls007
    Maybe if you got it between the vapor barrier and the drywall, I doubt it would work with blown in insulation.
  8. #8
    Join Date
    Sep 2004
    Durham, NC
    Posts
    5,500
    Well I do usually have a fish tape I need a fiberglass one though.
    I' ve been known to use a lead sinker.
    I thought the whole idea of go fishing is to have a sting on the line...
  9. #9
    Join Date
    May 2003
    Leesburg, VA
    Posts
    7,069
    I used a fish tape or washer on a string, took my 25' tape folded it at the 36" mark and filled the void with it, dropped the string/fish tape then pull out the tape out.
    Brian John
    Leesburg, VA
  10. #10
    Join Date
    Mar 2008
    Indiana
    Posts
    2,547
    Thumbs up
    Quote Originally Posted by brian john
    thats a pretty cleaver use of a measuring tape, I will have to remember that:wink:
Posting Permissions
  • You may not post replies
  • You may not edit your posts
