I'm doing a renovation where there are 2 pole switches in restrooms. 1 pole connected to the normal circuit, and 1 to the emergency. This way if you enter the room both circuits are energized and if the power goes out the emergency switch is sure to be on. This is instead of 2 seperate switches.
Does anyone see a code violation having the normal and emergency circuits connected to the same switch in the same box?
Thanks!!!
Bookmarks
