Results 1 to 3 of 3
Thread: NEC Article 645 and NFPA 75
  1. #1
    Join Date
    Jun 2008
    Campbell CA
    Posts
    226
    Hi everyone, I like to know if there is any exceptions to requirements NEC-645 which permits a IT room not to be fire resistant-rated walls, no need for EPO's as per 645-10, and that we donot have to install fire/smoke dampers.
    Thanks in advace for the input.
  2. #2
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    All of Article is 645 is voluntary unless you want to take advantage of the leniences it allows in wiring methods.
  3. #3
    Join Date
    Feb 2003
    New York, 40.7514,-73.9925
    Posts
    4,454
    Well said by Bob.
    645.4 indicates that the article only applies if you provide EPO's, fire rating, etc.
    NFPA 75 is a standard and not a code adopted by any jurisdiction that I am aware of.
    Ron
Posting Permissions
  • You may not post replies
  • You may not edit your posts
