#1
I went to a local energy conservation fair last Saturday, and there was a guy there selling a power conditioning box for homeowners. It was basically a box of capacitors that maximizes power factor, compensating for the low power factor of electric motors. He claimed that this would reduce utility bills. I said he was wrong, because the home owner isn't charged by the power company for low power factor. Industry is, because the peak currents are large and the line resistance loss in the grid is significant. But the homeowner only pays for the part of the current that's in phase with the voltage. He insisted, claiming that he timed the rpm of his meter rotor and found that the meter turns slower when his bix is connected. I said maybe something in the house switched off when his box was attached. What do you guys think? Scam or not?
__________________
When All Else Fails Use a Bigger Hammer |
#2
it is a scam
#3
Already discussed several times. consensus is SCAM/ snake oil...etc...
__________________
Make something idiot proof and someone will make a better idiot. |
#4
Scam, big time, and for the exact reason you named. Do a word search on this forum, and you will see several similar discussions.
I would tend to reply, to the saleman's description of his own experiment, that if he can connect a device to a residential service, and if that device can, with all else remaining the same, cause the meter to turn noticeably more slowly, then that device probably contains some component that is illegally altering the way the meter operates.
__________________
Charles E. Beck, P.E., Seattle |
#5
I agree. It's a scam.
#6
Quote:
__________________
Laszlo Z Weress Staff Engineer BASF, The Chemical Company Just because it works it doesn't mean its right! |
#7
Read what Mr. Electricity has to say- click here
Here is some of his comments Quote:
__________________
The National Sarcasm Society Like We Really Need Your Support Last edited by Dennis Alwon; 09-24-2008 at 03:21 PM. |
#8
Quote:
Dennis, thanks for the link!
__________________
#9
Quote:
BTW, just how long did he stand there counting the revolutions of meter?
__________________
ĦĦĦĦĦĦĦĦĦĦĦĦ ««« CELTIC »»» ĦĦĦĦĦĦĦĦĦĦĦĦ An error on your part does not constitute an emergency on my part.8-) |
#10
Similar scams have been tried here in the UK.
Residential customers here are billed for KWH just as in the USA and no financial saving is possible by improving the power factor. Large industrial users who pay a maximum demand charge based on peak KVA, not peak KW may achieve a saving, though large installations are often equiped with power factor correction already. |
| Tags |
| capacitor, power factor, residential power factor, snake oil |
| Thread Tools | Search this Thread |
| Display Modes | |
