Closed Thread
Results 1 to 4 of 4
Thread: NEC article 210.4(B)
  1. #1
    What is the intent of NEC 210.7(B)? We have a local official attempting to use this rule for a 3 Circuit Systems Furniture application.
  2. #2
    Join Date
    Oct 2006
    Baltimore, MD
    Posts
    3,159
    Quote Originally Posted by Jeff in Sacramento
    210.4(B) or 210.7(B)? Your post has one, your heading the other.
    Are you under the '08?
    And also take a look at 605.6 and 605.7
    John from Baltimore
    "One Day at a Time"
    Responses based on the 2008 NEC
    If you can stay calm, while all around you is chaos...then you probably haven't completely understood the seriousness of the situation
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    23,556
    I assume you mean 210.7(B) but your post title states 210.4(B).
    If you have 2 circuits that land on a device then you must use a dp breaker. If you are using MWBC then you have to use a 2p or 3p breaker anyway.
    The intent is to protect someone from pulling out a recep. that was assumed disconnected because one side of the recep. was dead. If they were on 2 separate sp breakers then there is a possible of shock or shorting the circuit.
  4. #4
    Join Date
    Feb 2006
    Pa.
    Posts
    1,988
    Quote Originally Posted by JohnJ0906
    Multiwired branch circuits feeding furniture systems required a commom trip starting in 2005.
    Rick
Closed Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
