relaytech
- United States
I have searched the code and cannot fine the answer to my situation. here is my situation. if you are facing the utility meter, there is a 200 amp service disconnect/main to the left of the meter. This service disconnect is also where the service enters the building to the main breaker panel. to the left of the service disconnect is a 200amp transfer switch. what i am trying to figure out, is it code legal to pass the source(from meter )thru the existing disconnect to the utility connection on the transfer switch then from the common feed on the transfer switch back thru the same raceway to the service disconnect box then into the main panel in the house?
thanks
thanks
