Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: PVC, glue, freezing weather, etc.
  1. #1
    Join Date
    May 2005
    Global
    Posts
    42
    Question PVC, glue, freezing weather, etc.
    Really 3 questions...
    1. What concerns should I have about installing PVC conduit in sub-freezing weather (say around 15F)?
    2. Is the glue OK to use after it froze and thawed out again?
    3. Why would anyone wrap duct tape over a PVC to galv. metal coupling connection (which will be covered in concrete)?
  2. #2
    Join Date
    Aug 2007
    Posts
    2,754
    read the instructions. some glues are ok for cold, some not.
  3. #3
    Join Date
    Jan 2004
    Right here.
    Posts
    12,326
    Quote Originally Posted by Mustangx3 View Post
    3-- to keep the Crete juice out
  4. #4
    Join Date
    Mar 2006
    Tampa Florida
    Posts
    8,009
    i do know pvc is very brittle in cold and breaks easy. Not seen 15 degrees in several years. Anything below 30 is too cold to get out of bed here. I dont even like 40's here in SUNNY FLA
  5. #5
    Join Date
    Feb 2006
    Memphis, TN
    Posts
    565
    I often come unglued at 15 degrees
    Rick. Shelby county TN. 2002 code cycle.
  6. #6
    Join Date
    Oct 2006
    Litchfield, CT
    Posts
    8,699
    As already mentioned, they make cold weather PVC Glue.
    "Electricity is actually made up of extremely tiny particles called electrons, that you cannot see with the naked eye unless you have been drinking."
  7. #7
    Join Date
    Mar 2003
    New England
    Posts
    13,224
    They also make PVC glue in a spray can. It's useless for anything above 1" fittings though, as the can runs out too quickly.
  8. #8
    Join Date
    Mar 2006
    Tampa Florida
    Posts
    8,009
    Quote Originally Posted by stickboy1375 View Post
    When it gets cold here i will buy some .
  9. #9
    Join Date
    Mar 2003
    New England
    Posts
    13,224
    Quote Originally Posted by Jim W in Tampa View Post
    Wow Jim, you're really rubbing it in today, aren't you?
  10. #10
    Join Date
    Oct 2006
    Litchfield, CT
    Posts
    8,699
    You da man!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
