Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Fire alarm voltage question
  1. #1
    What is the nominal zone circuit voltage in an addressable fire alarm system?
    I am thinking 24 volts, but it has been a while.
    Thanks
    Rick
  2. #2
    24 - 32 vdc
  3. #3
    Join Date
    Sep 2008
    Northern Indiana
    Posts
    178
    And 12vdc for some hybrid systems, so it depends on the system...
    Jim
  4. #4
    Thanks for the input. The reason I ask is, I am applying for a job with an electrical contractor. Part of the application is a 10 question mini quiz.
    I posted the question just as they asked it.
    This was the only one I didn't readily know.
    Thanks again.
    Rick
  5. #5
    Join Date
    Jan 2005
    Spotsylvania, VA
    Posts
    1,149
    9 out of 10 times you will be looking at a 24V system.
  6. #6
    Join Date
    Jul 2006
    San Francisco bay area
    Posts
    279
    Cool The answer is: it depends.....
    For EST2 or EST3 equipment (including all the companies EST private labeled these panels for, such as Siemens, Honeywell, & Mirtone) or SIGA type devices on EST IRC3 or FCC panels that incorporate older ZAS2 cards, the answer is 8 volts.
    In battle, in forest, at the precipice in the mountains,
    On the dark great sea, in the midst of javelins and arrows,
    In sleep, in confusion, in the depths of shame,
    The good deeds a man has done before defend him.
    --Bhagavad-Gita
  7. #7
    Quote Originally Posted by rick schultz View Post
    Thanks again.
    Rick
    So you cheated on a test. NICE!!!!!
  8. #8
    Join Date
    Sep 2008
    MN
    Posts
    74
    Thanks
    Rick
    What a strange question......Zone circuit in an addressable system ? being as it's an addressable system it's no longer a zone based or conventional FA panel. The only zones in an addressable panel are software zones. This must be referring to the Signaling line circuit.....?
  9. #9
    Join Date
    Jan 2009
    Posts
    18
    Silent Knight makes several panel that are addressable and you can make the flexputs in zone loops
    sorry just being a smart a**. I see what you are saying!!! :wink:
  10. #10
    Join Date
    Sep 2008
    Northern Indiana
    Posts
    178
    Quote Originally Posted by Stallzer View Post
    Good point.
    Ultimately, it's panel dependent and as most panels can only use their own devices on the addressable circuit, why would one care? Maybe just FYI...
    Maybe it's a trick question. :wink:
    Jim
Posting Permissions
  • You may not post replies
  • You may not edit your posts
