Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
Thread: Split Bolt
  1. #21
    Join Date
    Dec 2006
    Eastern Oregon
    Posts
    3,483
    Quote Originally Posted by peter d View Post
    I've said it before and will say again that I cannot for the life of me understand why anyone would still use a split bolt for anything other than bare conductors in this day and age. :confused:
    I agree, I've never bought one!
    Insulated taps for me....
  2. #22
    Join Date
    Oct 2006
    Litchfield, CT
    Posts
    8,699
    I agree, why on earth would someone use a split bolt?
    "Electricity is actually made up of extremely tiny particles called electrons, that you cannot see with the naked eye unless you have been drinking."
  3. #23
    Join Date
    Aug 2007
    Rhinelander WI
    Posts
    1,573
    I realy like the Polaris fittings. Never used the Kup-L-Taps. My first instincts are to be leary of anything that is insullation piercing. Perhaps someone with more experience here could asuage my fears.
  4. #24
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,575
    Quote Originally Posted by iaov View Post
    If it helps any, they have break-away bolt heads, so you can't under- or over-torque them.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #25
    Join Date
    Feb 2006
    new york
    Posts
    4,258
    I have used them many times and as you are I am very leary of them so I have a tendancy to install a bit more analy than other methods. My bosses had me install them and they have never failed to my knowledge as of yet. Polaris is my first choice then splitbolt then whatever my personal preference.
    The tail does NOT wag the dog.
  6. #26
    Join Date
    Feb 2009
    earth
    Posts
    631
    Haven't ya ever used those screw on caps for temporary lights?
    Two things are infinite : the universe and human stupidity; I’m not sure about the universe.
  7. #27
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by LarryFine View Post
    I don't believe using a device rated for this use qualifies as "working hot" any more than touching the insulation of an energized conductor.
    I don't know if you've ever seen or used one of these, but you'd have to go out of your way to try to make contact with any energized parts.
    I still do not believe they are designed for hot installation.
    Regardless of being hard to make contact with live parts you would be in for a world of burns if you clamped into a faulted conductor.
  8. #28
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,575
    Quote Originally Posted by iwire View Post
    It says they are on the page to which I linked, as long as there is no load.
    That conductor would already be the energized one; it would be the tap conductor I just installed that could be the faulted one.
    However, I always use my K-60 to check each of my new conductors against an energized conductor first, for just that reason.
    In fact, I do the same thing the first time I energize any new circuit or conductors.
    Larry B. Fine
    Master Electrician
    Richmond, VA
  9. #29
    Join Date
    Jun 2004
    San Francisco, CA
    Posts
    5,468
    (Page 4)
    Apparently not UL or CSA listed?????
    As for insulation piercing (I use the burndy version on page 36.) there is a time and place for them. I wouldn't use them in a gutter - but use them on OH service conductors all the time. Local POCO considers any splice they did not do temporary - so why waste time? (Although they often take a year to come out to re-splice)
    Gutters or cans I use Polaris.
    Electric heretic
    It's always gonna be in the last place you look....
  10. #30
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,575
    Quote Originally Posted by e57 View Post
    I found them on p21, where the ability to install them on hot conductors is repeated.
    there is a time and place for them. I wouldn't use them in a gutter . . .
    I am curious as to why you would not, as I have; that's one of their main attractions.
    Larry B. Fine
    Master Electrician
    Richmond, VA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
