Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: (2) 200 amp panels on 200 amp service.
  1. #1
    I'm sure this is an easy one, but I've never sone a service like this, so I am asking. I have a 200 amp service for a single family dwelling. I want to run two 40 circuit panels from this service, but with each panel being able to support 200 amps. The transfer switch can't be double lugged, so I am making connections in the trough. Is this even legal? If so, do I have to mark the panels with circuit #'s 1-80?
    Diagram
    Tight is right, too tight is broken.
  2. #2
    Join Date
    Mar 2006
    SW Florida
    Posts
    2,558
    Quote Originally Posted by StreamlineGT View Post
    Diagram
    can you say 400 amp xfer switch?
    Unlimited Electric Contractor/Standard Electric Inspector/Traffic Signal Inspector/Highway Lighting and Level One Traffic Signal Installer.
    I know you believe that you understand what you think I said but I'm sure you realize that what you heard is not what I meant.
  3. #3
    Join Date
    Jun 2005
    Delmarva, USA
    Posts
    1,645
    ...The transfer switch can't be double lugged, so I am making connections in the trough. Is this even legal?....
    Yup. Perfectly legal. AS long as your conductor size is sufficient for the loads served.
    ... do I have to mark the panels with circuit #'s 1-80?
    As long as they are accurately marked you can call `em anything you want to. :grin:
  4. #4
    Join Date
    Feb 2006
    Pa.
    Posts
    2,021
    Quote Originally Posted by Cavie View Post
    You'll have to watch with a 400 amp service rated x-fer switch (main included) the 200 amp ML panels will require a main breaker set at 200 amps each.
  5. #5
    Why would I have to goto a 400 amp transfer switch? The transfer switch has a 200 amp main breaker in it. Therefore the service with be 200 amps, with an 80 circuit panel.
  6. #6
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,467
    with a "service rated" 200 amp transfer switch as the service equipment, as long as you have not exceeded your calculated load, I see no problem.
    Add as many panels as you like.
    (1 breaker per outlet :-) )
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  7. #7
    Join Date
    Nov 2007
    Posts
    1,631
    leave more room for tel and catv, and wheres the network wiring?
  8. #8
    Quote Originally Posted by wireguru View Post
    No networking, just a wireless setup. Not really into the computer thing, so they said they didn't need it. They are already over budget on the things they wanted in the house, like 106 recessed cans (house is 3000 sq ft.), and a stand-by generator.
  9. #9
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,467
    3000 sq ft. Depending on the type heat and many other varibles, 200 amp might be questionable. Did you (or anyone) do a load calculation ?
    In this area it would be more common to see one of the panels connected as service (for non-generator loads0 as well as the transfer switch.
  10. #10
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,510
    Is the transfer switch supposed to transfer power from one 40 cir panel to the other? :-?
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
Posting Permissions
  • You may not post replies
  • You may not edit your posts
