Results 1 to 4 of 4
Thread: fire Pump Service Disconnect switch
  1. #1
    In NYC can a fire pump service disconnect switch located remote from the electrical service room and be located in teh fire pump room?
    Thank you
  2. #2
    Join Date
    Jul 2008
    nyc
    Posts
    238
    You would have to submit advisory board drawings for approval.
    cmac1
  3. #3
    Join Date
    Feb 2003
    Massachusetts
    Posts
    59,412
  4. #4
    Join Date
    Sep 2004
    Durham, NC
    Posts
    5,491
    Fire pumps are there own animals, besides it being NYC, you've now double'd down!
    Your Local AHJ will have well defined rules, applications and their own limits.
    The only one aspect that inverse the thought process here as to an electrican's everyday thought in respects to fire pumps is: that the Circuit is breaker'd, as opposed to always breaker a circuit.
    IE A fire pump is front loaded and always hot to a breaker, where every day we breaker a circuit!
    If you are even thirsty, you are two quarts low.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
