Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Liquid Tight vs. Sealtite
  1. #1
    Join Date
    Feb 2003
    NewYork
    Posts
    143
    Are they the same? If not, what are the differences?
    Thanks.
    c
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,147
    In my world they're the two terms are interchangeable. Sealtite is a brand name.
    Rob
  3. #3
    Join Date
    Apr 2008
    Austin, TX
    Posts
    1,155
    Quote Originally Posted by infinity View Post
    I agree. Also, in industrial settings where "Greenfield" is rarely used, I've heard Sealtite called "flex".
  4. #4
    Join Date
    Oct 2006
    Burke, Virginia
    Posts
    2,561
    Quote Originally Posted by cvirgil467 View Post
    Thanks.
    c
    Look at NEC Article 350 for LFMC and Article 356 for LFNC. Do you have an NEC? Agreed sealtite is simply a brand name and should be covered under LFNC.
    Greg
    Electrical Inspector in our Nations Capital
  5. #5
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,486
    Sealtite is a company name. We use the term for liquid tight flexible metal conduit. Others use it for non-metallic liquid tight conduit. On the last job I did all the FMC came from Sealtite and the boxes the small rolls came in had the Sealtite logo on the box. In fact, I don't even see the product we call Sealtite on the company's web site:
    http://www.anacondasealtite.com/products.htm
    When working in different areas it's best to stick with the NEC terms until you become familiar with the local electrical slang.
    Another example is 'flex'. In this area the term refers to MC cable. 40 miles from here the term refers to flexible metal conduit.
    How many of you have used a Chicago bender? If it was a Greenlee it was simply a Chicago 'style' bender. I own two real Chicago benders and have copies of the patents for them. They are red and black and are made by a company named Lidseen, after the inventor Gustave Lidseen. BTW, the real Chicago bender was 77 years old on April 2nd of this (2009) year.
    Cheers and Stay Safe,
    Marky the Sparky
  6. #6
    Join Date
    Nov 2006
    Posts
    832
    Thanks.
    c
    It is exactly the same as one referring to in-line skates as Roller Blades, a pair of side cutters as Kleins, "an Americans best interest" as "the government"...........
    I am totally joking about the last one!:grin:
  7. #7
    Join Date
    Dec 2004
    Windsor, CO NEC: 2017
    Posts
    16,108
    In my area, "sealtight" is LFMC, and "carflex" is LFNC. Using the term "liquidtight" prompts the question, "Metallic or nonmetallic?"
  8. #8
    Join Date
    Jul 2008
    Michigan
    Posts
    1,904
    Quote Originally Posted by George Stolz View Post
    That's how we look at the terminology in my area as well.
  9. #9
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    21,896
    I'll third that. And flex refers to FMC.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  10. #10
    Join Date
    Mar 2003
    New England
    Posts
    13,135
    Quote Originally Posted by LarryFine View Post
    I'll fourth that. I've heard the term "greenfield" used a few times, but mostly "flex" is FMC.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
