Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Ground Rod - Spacing
  1. #1
    Join Date
    Jun 2007
    Posts
    720
    Someone please clarify for me for required ground rod spacing, here is what I recalled from NFPA780 and NEC:
    NFPA780 (lightning protection system): the spacing between rods shall not be smaller than the sum of all ground rod length..
    NEC article 250...spacing between ground rod is min. 6 feet.
    So, which rule should we go with? If we go with NEC, we are ok at spacing ground rod 6' apart as minnimum. If we go with NFPA 780, we have to space them at least 24 feet apart (assume 8' long ground rod)...
    Or ground rod spacing rule per NFPA-780 only applies to lightning protection system? I saw several electrical grounding details where they showed the rod either 20' or 15' apart for tri-rods system.
  2. #2
    Join Date
    Aug 2006
    Cape Cod, Massachusetts
    Posts
    632
    NEC 6' apart
  3. #3
    Join Date
    May 2003
    Leesburg, VA
    Posts
    7,072
    Quote Originally Posted by dSilanskas View Post
    NEC 6' apart
    That's not necessarily true.
    It depends on what you want and what you are installing them for, if you are looking for the most effective use of your driven electrodes you would go twice the lenght of the electrode 8' X 2 = 16' (not 24'?).
    Brian John
    Leesburg, VA
  4. #4
    Join Date
    Feb 2003
    Fl
    Posts
    17,095
    Let's take note that the NEC says "they shall not be less than 1.8 m (6 ft) apart.", it does not say they shall be 6' apart.
    Roger
    Join Date
    May 2003
    Leesburg, VA
    Posts
    7,072
    Quote Originally Posted by roger View Post
    Roger
    VERY TRUE, we had an inspector turning down contractors for spacing over 6'.
    Brian John
    Leesburg, VA
  6. #6
    Join Date
    Jul 2008
    Michigan
    Posts
    1,904
    Quote Originally Posted by brian john View Post
    That's ridiculous if you were off by a small amount either way you would fail. As you stated in your other post 6' is not ideal anyway.
  7. #7
    Join Date
    Mar 2006
    SW Florida
    Posts
    2,558
    I belive the op is refering to 'Lightning protection system". that is different than grounding a service.
    Unlimited Electric Contractor/Standard Electric Inspector/Traffic Signal Inspector/Highway Lighting and Level One Traffic Signal Installer.
    I know you believe that you understand what you think I said but I'm sure you realize that what you heard is not what I meant.
  8. #8
    Join Date
    May 2004
    MA
    Posts
    1,472
    NFPA 780 is the Standard for the Installation of Lightning Protection Systems. The NEC nolonger has a article on lightning protection I believe it was 280???
    in 780 you probably would have to extend the spacing to 24 or whatever feet.
    Charlie
  9. #9
    Join Date
    Jan 2008
    Raeford, NC
    Posts
    3,682
    Roger
    That tells me that over 6' is OK. 5ft 11in is LESS THAN 6ft
    Organized people are people that are just too lazy to look for their stuff
  10. #10
    Join Date
    Nov 2007
    massachusetts
    Posts
    3,166
    hey brian what would be the reason you would want to space the ground rods apart that far? i usually space them 8 feet apart for a house. never really had to do any fancy grounding like you do
    "Most good electricians are pretty sure that they are the best and the great ones never stop trying to be."
Posting Permissions
  • You may not post replies
  • You may not edit your posts
