225.18 Clearance for Overhead Conductors and Cables. (3)
fmtjfw
Section/Paragraph: 225.18 Clearance for Overhead Conductors and Cables. (3)
deleted
225.18 Clearance for Overhead Conductors and Cables. ....
(3) 4.5 m (15 ft) ? for those areas listed in the 3.7-m (12-ft) classification where the voltage exceeds 300 volts to ground
Substantiation:
Extraneous "-" between number and "m".
inserted deleted
GoldDigger
Placerville, CA, USA
Retired PV System Designer
And why, if there is a standard style, are both '15 ft" and "12-ft" acceptable?
Is one the noun use and the other the adjective use?
I think you may be overlooking that some code references have one usage while others have the other...
When spelled out in full, we have in one case a distance of fifteen feet, and in the other we have a twelve-foot classification (and compound adjectives normally require a dash.)
Tapatalk!
fmtjfw
Tapatalk!
Another good comment, I'll check it out.
Thanks
don_resqcapt19
Illinois
retired electrician
deleted
Substantiation:
inserted deleted
Again there is no confusion here, no one is mis-applying the code rule and there is absolutely no reason for a change.
