Go Back   Mike Holt's Forum > NEC
Forgot Login Information?
Register FAQ About Moderators Members List Calendar Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Search this Thread Display Modes
  #1
Old 04-30-2009, 08:08 PM
mitch cochrell mitch cochrell is offline
Junior Member
Default Underground junction box
I am trouble shooting some pole lights in a parking lot at a commercial retail center. There is an under ground junction box in the middle of one of the lanes and is full of wires that are spliced. The box is full of water and when we turn the breakers on you can hear the conductors arching under the water. Is there any way to replace this junction box and have it water tight?
  #2
Old 04-30-2009, 08:20 PM
480sparky's Avatar
480sparky 480sparky is offline
Default
Quote:
Originally Posted by mitch cochrell View Post
...... Is there any way to replace this junction box and have it water tight?
Not really. Remake the connections with a water-tight system instead as water will always find it's way into an underground box.
__________________
All posts entered between 4:17 and 4:18 AM CDT will be worded to please Bob.
  #3
Old 04-30-2009, 08:46 PM
SiddMartin SiddMartin is offline
Default
Quote:
I agree, only way you can do it.
  #4
Old 04-30-2009, 08:47 PM
ultramegabob's Avatar
ultramegabob ultramegabob is offline
Default
I use gel filled wire nuts and then dip them in Plasti-coat...
http://www.plastidip.com/home_solutions/Plasti_Dip
__________________
THIS SPACE FOR RENT
  #5
Old 04-30-2009, 08:52 PM
Jim W in Tampa's Avatar
Jim W in Tampa Jim W in Tampa is offline
Default
Lot of silicone and just redo every connection. Personally would solder them and shrink rap. Just no good way to make it last. Call it a design problem. Would been smarter to made splices within the poles at the covers.
  #6
Old 04-30-2009, 08:53 PM
Twoskinsoneman's Avatar
Twoskinsoneman Twoskinsoneman is offline
Default
Quote:
shame on you
__________________
We will conquer land with water!
  #7
Old 04-30-2009, 09:04 PM
Default
also, you can use a wet/dry vac to get the water out of the box, sometimes it takes quite a bit of vacuuming to get all the water that is backed up into the conduits that keeps running into the box....
__________________
THIS SPACE FOR RENT
  #8
Old 04-30-2009, 09:09 PM
Default
Quote:
Then fix fast because water be back in few hours. Turn power off first or you might suck up electrons
  #9
Old 04-30-2009, 09:24 PM
hillbilly1 hillbilly1 is offline
Default
Your pretty much screwed down there with the high water table, when I come across one of these screw ups, I take the box out and replace it with an open bottom Quasite box. Set the quasite box on a deep bed of gravel to help drainage (will not work well were your at) seal connections as best as possible. I just got through fixing one that was buried almost three feet deep! Would not have know it was there, but logic dictated that's what someone had done, there was only one conduit out of the pole that was in the middle of a run.
  #10
Old 04-30-2009, 11:07 PM
rt66electric rt66electric is offline
Default make you lid tight
remember gradeschool science exp-- when you invert a glass and push it underwater,the air is trapped in the glass and remains air tight. the same is true in a UG box, either have a airproof lid, or place a inverted coffee can or such on top of the joints to keep the joints dry.. the water level may rise, but there is trapped air (and joints) under the plastic coffee can...:smile:
Closed Thread
CEU Banner Home Page
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
- Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
