Results 1 to 3 of 3
Thread: PVC to rigid
  1. #1
    Join Date
    Jun 2009
    Posts
    2
    Question PVC to rigid
    When going from pvc underground to rigid risers into panels on 480 volt system are the 2 lock nuts good enough to ensure the bonding of rigid pipe? KO is clean not eccen. or cocenn. I thought a bond bushing would be required because pipe run is not electrically continous from one end to other.
  2. #2
    Join Date
    Mar 2004
    Arizona
    Posts
    3,913
    Quote Originally Posted by aarong View Post
    Check out 250.97 ex#3 you are good.
    Welcome to the Forum !!
    Frank Arizona,USA
  3. #3
    Join Date
    Jun 2009
    Posts
    2
    looks like 2 lock nuts are good enough even when pipe run is not electrically continous. Oops.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
