Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Greenfield vs. Flex conduit
  1. #1
    What is the difference between these two types of conduit? Can you use the same fittings for both?
  2. #2
    Join Date
    Jun 2005
    Logan, Utah
    Posts
    8,193
    As far as I am aware, "Greenfield" is a trade term for flexible metal conduit, so greenfield and flexible metal conduit are the same thing. This is like asking if I can use a "romex" connector for nonmetallic sheathed cable.
    Chris
  3. #3
    Join Date
    Feb 2003
    Minnesota
    Posts
    6,606
    I agree with Chris. Greenfield = FMC. Just like calling a Ryobi hand held reciprocating saw a Sawzall (registered name by Milwaukee Electric Tools).
    Another Al in Minnesota
  4. #4
    Join Date
    Mar 2006
    SW Florida
    Posts
    2,558
    In some areas, the steel version is called Greenfield and the ALM version is called flex.
    Why? I don't know, 1ST Base!
    Unlimited Electric Contractor/Standard Electric Inspector/Traffic Signal Inspector/Highway Lighting and Level One Traffic Signal Installer.
    I know you believe that you understand what you think I said but I'm sure you realize that what you heard is not what I meant.
  5. #5
    Join Date
    Jun 2006
    Ohio
    Posts
    21,385
    Quote Originally Posted by martinvalley View Post
    As I recall, the original version of Greenfield "cable", circa 1920, was the forerunner of BX, and more modern AC, and MC, as it was furnished with wire already in it. It resembled more so FMC with wire in it than the more tightly wrapped BX.
    http://www.bejane.com/electricity_101
  6. #6
    Join Date
    Oct 2006
    Burke, Virginia
    Posts
    2,561
    I reckon it is like trying to define pornography......Don't know untill I see it.
    Greg
    Electrical Inspector in our Nations Capital
  7. #7
    Join Date
    Feb 2003
    Fl
    Posts
    16,810
    Actually Greenfield was always just flexible conduit and goes back to 1902 it got it's name from the inventor.
    Excerpt from this article
    When you decide to use "Greenfield" on the job you are really dating yourself, so I would just call it "flex". It was invented in 1902 by Harry Greenfield and Gus Johnson and when it was listed by Sprague Electric Co. it was called "Greenfield flexible steel conduit". Today the term "Greenfield" is commonly used for all FMC (flexible metal conduit-NEC Art. 348). FMC is also manufactured in both aluminum and steel. The NEC defines FMC as "A raceway of circular cross section made of helically wound, formed, interlocked metal strip."
    Roger
    Join Date
    Aug 2008
    Posts
    216
    Martin,
    What kind of Sales Manager are you?
    Are you in the electrical field?
    What do you mean by "Flex"? Are you refering to FMC (Flexible Metallic Conduit) or are you refering to ENT (Electrical Non-metallic Tubing, the blue stuff)?
    I will assume (uh oh!) you are not refering to flexible liquidtight.
    Some places call ENT "flex".
    Humility is that ever elusive state. Once you think you've finally got it, you just lost it.
  9. #9
    Join Date
    Oct 2006
    Burke, Virginia
    Posts
    2,561
    Quote Originally Posted by cycotcskir View Post
    Martin,
    That was the reason or intent of my post #6 Way too many people use field slang and not the actual terminology.
    Greg
  10. #10
    Join Date
    Apr 2007
    OHIO
    Posts
    24
    Glad they went with flexible Greenfield rather than flexible Johnson......:rolleyes:
    Let me drop everything and work on your problem!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
