Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 1600 amp wire size calc
  1. #1
    Talking 1600 amp wire size calc
    my question is about sizing conductors for a 1600 amp single phase service.
    would 4 - # 500 MCM copper THWN-2 RATED FOR 90 C per phase be adequate
    the run is less than 6 feet from ct cabinet to service disconnect
    the allowable ampacities chart says 500 mMCM is good for 430 amps x 4 = 1720
    Thanks for any comments
  2. #2
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,936
    Sorry, but no. You can't use the 90C column for ampacity, unless all the components in the circuit are rated for 90C. The one that generally gets you is the terminations. They are seldom rated higher than 75C. So you can only use the 75C ampacity. Reference 110.14(C).
    Thus, four 500's are only good for 4 x 380, or 1520 amps.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  3. #3
    Join Date
    Aug 2006
    Miami Fla.
    Posts
    7,440
    See above.
  4. #4
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,865
    agree, but, to cover all possibilities: when you say "service disconnect" are you referring to one means (1600 amp breaker or bolt-lok switch, etc.) ?
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  5. #5
    Talking
    charlieB
    good answer.
    We are looking into the lug rating (probably 75-c )
    will have to increase conductor size, thankfully it is a very short run
    Why dont manufactures just use 90-c rated lugs ?
    Thanks again for an A++++ answer
  6. #6
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by electromantoo View Post
    The lug itself may actually be rated 90 C, but the equipment (breakers, fused disconnects, etc) it is connected to will not be.
    Why don't manufactures just use 90-c rated lugs ?
    It would be difficult to make a breaker that could handle a 90 C conductor and still not trip early due to heat.
    That said, I agree with the others, you will need 600 copper or a reduction of the over current protection.
  7. #7
    Join Date
    Aug 2006
    Miami Fla.
    Posts
    7,440
    Is this a common service in other areas? 1600A 240/120 1 3 wire system. That system at that amperage is very uncommon here. (as in I have never seen one).
  8. #8
    Join Date
    Feb 2003
    Massachusetts
    Posts
    60,020
    Quote Originally Posted by chris kennedy View Post
    Same here.
  9. #9
    Join Date
    Aug 2007
    Posts
    2,754
    maybe you could post a pic of this service ?
  10. #10
    Join Date
    Mar 2004
    Arizona
    Posts
    3,913
    The good news is there is one less conductor per phase ( to upsize ).
    Frank Arizona,USA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
