MRTEASOLAR
New member
- Merced, CA, USA
Greetings to all,
I would like input from you all relating to entering a 3R gutter from above using only a Raintight compression connector. In your experience, is it sufficient to trust the gasket? It appears to me the gasket distorts upon tightening and my concern is water entering the enclosure. Is a meyers hub, then the raintight compression connector a good combination? Or is using a washer in conjunction with the gasket an acceptable added measure?
Is there any links to UL stating acceptable entrance to 3R enclosures from above?
Cheers!
Cheers!
