Results 1 to 5 of 5
Thread: what is the largest solid wire
  1. #1
    Join Date
    Apr 2010
    tampa, Florida
    Posts
    1
    what is the largest solid (nonstranded) conductor listed in the wire tables?
  2. #2
    Join Date
    Jan 2009
    Maryland
    Posts
    13,044
    #4 solid copper is the largest I have used.
    Table 8 of Chapter 9 shows #8 as the largest listed, perhaps because 310.3 limits solid wire to #10 if installed in conduit.
    MI cable is another possibility; however, I have never installed any, so I do not know.
    You could search manufacturers like Southwire if you need to know.
    "Electricity is really just organized lightning." George Carlin
    Derek
  3. #3
    Join Date
    Mar 2008
    Michigan. It's a beautiful penninsula, I've looked around.
    Posts
    9,486
    I have run #2 SBTC (solid bare tinned copper) for grounding. Anything larger would likely be considered rod, not wire.
    Cheers and Stay Safe,
    Marky the Sparky
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    21,896
    Quote Originally Posted by K8MHZ View Post
    As have I, at a cellular site. That stuff Cad-welds well.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Mar 2004
    Posts
    590
    No. 1/0 solid aluminum is sometimes used in 15 kV URD cable.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
