billymons
- Kutztown, Pa
I'm doing the electric on my in ground pool and have done a lot of research on the codes but I have a question about the low voltage LED lights. It will be two Pentair Globrite lights. Per code is it alright to run PVC conduit from each light to a normal outdoor junction box that I mount on a 4x4 post? I see most guys use the J-box that comes out of the ground and Id rather not use that and keep everything neat near the pump. Thanks
