Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Light switch outside of room
  1. #1
    Join Date
    Jul 2007
    bay area, ca
    Posts
    1,573
    I have a room that the entry door is a double pocket door, and it takes up the whole wall. Can the switch for the light in that room [the study] be located outside of the room, or does it have to be in the room?
    ~Matt
    I would rather beg for forgiveness then beg for permission.
  2. #2
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,759
    It can be anywhere you want unless required to be there by some other code. The NEC doesn't specify a location as this is a design issue.
    Rob
  3. #3
    Join Date
    Jul 2008
    Michigan
    Posts
    1,904
    Thats been a hot topic for a long time. I agree with Rob not an NEC requirement.
    Steve
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,651
    You could put a switch on the nearest side wall, or even use a shallow box within the pocket space.
    How about a motion sesnor, maybe centered over the doors, or in the above-mentioned side wall?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Feb 2003
    Seattle, WA
    Posts
    18,890
    How about taking a lesson from the refrigerator? Put a limit switch on both sides of the pocket doors, such that the act of opening either door turns on the light, and closing both doors turns off the light.
    Charles E. Beck, P.E., Seattle
    Comments based on 2017 NEC unless otherwise noted.
  6. #6
    Join Date
    Feb 2008
    Carrollton, Texas
    Posts
    108
    You don't want a motion sensor in a study. Probably not a door switch either. Look for side wall wall nearest the door.
  7. #7
    Join Date
    Jul 2007
    bay area, ca
    Posts
    1,573
    Quote Originally Posted by charlie b View Post
    Wont work too well if they want to read a book in peace with the doors shut
    Thanks for your input fellas!
    ~Matt
  8. #8
    Join Date
    Feb 2009
    Durango, CO, 10 h 20 min without traffic from winged horses.
    Posts
    9,386
    Following up with what Charlie said, I've had good luck with these.
    Just saw your last post. You could add an override.
    If you go and decide to dance with a gorilla the dance ain't over till the gorilla decides it's over.
  9. #9
    Join Date
    Oct 2006
    Litchfield, CT
    Posts
    8,699
    "Electricity is actually made up of extremely tiny particles called electrons, that you cannot see with the naked eye unless you have been drinking."
  10. #10
    Just use a low voltage switch and a relay, and they it is all class-2 wiring that can easily be hidden. The switch itself can be a glorified surface mount doorbell.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
