Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
Thread: The white coiled wire attached to an AFCI
  1. #11
    Join Date
    Mar 2003
    3rd Rock from the Sun
    Posts
    949
    The manufacturer doesn't know where on the bussbar the installer will be placing the breaker.
    So, they provide a long enough tail to reach the neutral bar.
    They coil it to make it smaller packaging.
    When I see a GFCI or AFCI breaker installed with the neutral coiled up and never trimed to fit, I can't help but think that it looks, well, amateuristic
    -Todd-
    -Delawhere?
    Shock Me, Make Me Feel Better.
  2. #12
    Join Date
    Nov 2006
    Posts
    17
    Why not to cut the coiled wire on a breaker.
    The white coiled wire on any breaker is made that way so you can uncoil it to reach to the propper location in the panel that it will be terminated, other then that the only reason you wouldn't cut the wire is because if the breaker doesn't outlast the warrenty then by cutting the wire may give them a reason not to take it back.
  3. #13
    Join Date
    Nov 2006
    Posts
    17
    I try to locate the breaker far away from where the white wire will be terminated on the nuetral bar so when I uncoil the wire it doesn't have to be cut and it can be neat at the same time.
  4. #14
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    22,634
    I install the breaker where I want it, uncoil the wire, and trim it if needed.
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #15
    Join Date
    Mar 2008
    whitney point, NY
    Posts
    37
    Smile
    I don't spend much time thinking about it Too busy running a business.
  6. #16
    Join Date
    Feb 2006
    Lake of the Ozarks
    Posts
    2,875
    Way to much monkey see monkey do in this trade its good to ask these questions as it helps us become better teachers.
    Those who can do, those who can't teach
  7. #17
    Join Date
    Jun 2010
    Northern Virginia
    Posts
    345
    I usually stick my screwdriver in the coil, hold the wire where it comes out of the breaker and pull. If the neutral bar terminal I use is very near the breaker, I will leave the coil in the middle somewhere. After all, you never know what will happen in the future and you may be there re-arranging breakers someday!
  8. #18
    Join Date
    Jan 2008
    NC & IN
    Posts
    3,366
    Cool , thanks for the replies.
  9. #19
    Join Date
    Mar 2003
    Posts
    949
    Wire nut and tail at that point. Rarely is that ever needed.
    -Todd-
    -Delawhere?
  10. #20
    Join Date
    Mar 2007
    Valdosta, GA
    Posts
    3,931
    Quote Originally Posted by ty View Post
    That's the same thing I thought when I read your post.
    Brought to you by Carl's Jr.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
