Originally Posted by
dicklaxt
...If tapping on the relay works in this scenario then I believe the jarring of the relay is causing the contacts to momentarily open thus acting as a stop button located close to the source and dropping out the relay by breaking the control wire circuit continuity...
Dick,
I think the tapping of the relay causes it to open because the relay is operating at the very low end of the hold in current. The capacitive coupling is providing enough current to barely keep the relay closed. The physical force of tapping overcomes the magnetic force of the coil and it opens the circuit.
Don, Illinois
"It is the first responsibility of every citizen to question authority." B Franklin
Bookmarks
