User Tag List
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Milbank RV 50amp receptacles melting
  1. #1
    Join Date
    Jul 2008
    Posts
    45
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have 5 year old Milbank meter pole with RV 50 amp receptacles that are continually melting and I have to change them out. What is the cause of this? Is it just a loose connection between the receptacle and the male plug? There is nothing else odd here and it is happening at alot of my camp sites.
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    34,729
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    I suspect the RV vehicle plugs are worn out and have loose connections that are creating heat and melting your recep. Either that or all your recep. are loose.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Nov 2008
    NJ
    Posts
    75
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check the the cords that are being plugged in there. A lot of those molded rv plugs begin to burn, and then the loose connection just kills the receptacle.
  4. #4
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wow. This sure sounds familiar. This was about two months ago in a 1-year old panel.
  5. #5
    Join Date
    Feb 2007
    USA
    Posts
    5,875
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    poorly balanced panels in the RV?
  6. #6
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sierrasparky View Post
    They're all 120v, no matter what. RVs do not utilize 240.
  7. #7
    Join Date
    Feb 2007
    USA
    Posts
    5,875
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 480sparky View Post
    That picture is a 120/240v range outlet. So how is the RV wired.
    Don't the Rv have a 120v 50a outlet?
  8. #8
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    They're all wired for 120v. I have yet to see an RV that has a 240v load in them.
    If they have 240v loads, how do they plug into a standard 120v receptacle and have everything work?
    How do the work on 240v receptacles, and why do they use 240v cord & plugs? Simple.... they only utilize one hot wire. Half the RVs that plug in will use the hot on the 'right' side of the receptacle, and half will use the hot on the 'left' side of the receptacle.
  9. #9
    Join Date
    Feb 2007
    USA
    Posts
    5,875
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So You tell me that the manufacture makes cords with all 4 wires and only use 3. Really.
    Some RV's have 240v appliances. what I can bet on is that they all are wired with all the 120v on one leg. A Rv park gets overloaded on one Leg because the EC wires Line 1 on the same terminal on each and every pedistal. I can assure you there is a voltage drop on Line 1 when the park is full.
    I have seen this in condos where Line 1 is substatially heavier loaded than Line 2. When everyone is home the current on line 1 is drawn down because of the heavy load while line 2 is not loaded much at all.
    That is why it is essential to balance the load equally. It it difficult in resi. although in multifamily it is best sometimes to switch around the loading opposite that of half the complex.
    My 2 cents
  10. #10
    Join Date
    Jul 2007
    Iowegia
    Posts
    18,526
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ...........Some RV's have 240v appliances. ......
    RVs? Or mobile homes?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
