Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: TN-C-S vs TN-S
  1. #11
    Join Date
    Jul 2007
    Quote Originally Posted by charlie b View Post
    I'll clarify the need for clarification. I have two questions:
    1. What does "TN-C-S" mean?
    2. What does "TN-S" mean?
    It's grounding terminology from the other side of the pond
  2. #12
    Join Date
    Nov 2005
    Canterbury, New Zealand
    TN-S is a better (as in slightly safer in one particular respect) system than TN-C-S, but needs a lot more copper. So we use TN-C-S, which is good enough. TN-S is really impracticable as it makes distribution unwieldy and hard.
    TN-C-S is the standard wiring method used within the USA, the UK, Europe, New Zealand, Australia, and most civilized countries of the world.
    The -C bit means that the functions of neutral and Protective Earth (ground) are combined on one conductor, as is the case with the service supply. The -S bit means that from the service, the neutral and protective Earth (ground) condutors are seperate.
    So you guys use TN-C-S every day. incdentally these terms are international, not European, they are IEC I think.
    With TN-S the neutral and Protective Earth conductors are seperate from the point of generation or transformation.
  3. #13
    Join Date
    May 2010
    North of the 65 parallel
    Quote Originally Posted by electrics View Post
    hi, What would you say when you compare these two system , which one is more efficient ? When do we need to choose TN-C-S ,I guess this is worse than TN-S since common neutral and earth conductor might effect bad result, but I wonder the use area of this system...
    I know what a TN-C is. I know what a TN-S is. I don't know what a TN-C-S is.
    edit to add: Slow poster - already answered
  4. #14
    Join Date
    Oct 2008
    Cleveland, Ohio
    Although the following paper:
    "Power and Grounding For Audio and Audio/Video Systems -- A White Paper for the Real World"
    Is mostly about power and A/V systems, pages 39 to 41 cover internation power including TN-C-S (PME) systems.
  5. #15
    Join Date
    Nov 2009
    kinda the part especially from xformer to service entry of a building is TN-C while the distribution inside the building is TN-S .....
  6. #16
    Join Date
    Jan 2008
    Columbus, OH
    Sounds like ya'll answered his test question ...WTG
  7. #17
    Join Date
    Jul 2006
    From iwire's Rules for Posting thread at the top of every page:
    * This NECŪ Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
    Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
    The "National " in National Electrical Code is referring to the Nation of the United States of America. Because there are so many similarities, Canadians often get the same value from this forum. I'm not being xenophobic here, just pointing out that when people from other countries post in a forum based on the National Electrical Code, they should expect that the majority of readers are NOT going to know what acronyms mean from outside of North America. Please try to be clear up front in your postings and ass-u-me nothing.
  8. #18
    Join Date
    Jun 2009
    I thought it had something to do with Tennessee.
    I got a pretty good ABB Switchgear Handbook but didn't have a Tennessee code book.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
