Originally Posted by
beanland
OK, good clarification. That makes sense.
However, are conductors located in an enclosure considered in a conduit/raceway (310.16) or in free air (310.17)? NEC 100 defines a raceway basically as a conduit. Enclosures are defined totally differently. Based on the definitions, I have assumed that if it is not in a conduit(aka raceway), it is in free air, we do not have a third choice.
Conductor ampacities under the NEC are, for the most part, determined by the wiring method used between enclosures and the like.
Free-air wiring is generally considered to be that which has substantial air-space around wires... but the amount of air-space is not specified by the NEC. Typically, this is for open conductors (i.e. not a jacketed multiconductor cable or wires in a raceway, for the majority of their length). The NEC does have some conductor-to-conductor spacing requirements, though.
Whomever says or otherwise portrays "I am there" is a liar.
Bookmarks
