Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: 10 Point meter
  1. #1
    Join Date
    Jan 2008
    New York City
    Posts
    407
    10 Point meter
    I know it is not a code rule but usually for the 10 point meter wire what kind of conduit are you guys using ?.EMT or Rigid?
  2. #2
    Join Date
    Jun 2003
    NE (9.1 miles @5.07 Degrees from Winged Horses)
    Posts
    9,045
    Quote Originally Posted by DARUSA View Post
    Huh???? My ignorance is showing. What is 10 point meter?
    Tom
    TBLO
  3. #3
    Join Date
    Jul 2007
    Eatonton, Georgia
    Posts
    1,159
    Quote Originally Posted by ptonsparky View Post
    A 10 point ''buck '' and boost :grin::grin:
  4. #4
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,174
    A ten point meter pan is used with a three phase service that has CT's. It's been a while but I believe that you can use either. And don't forget the 10 conductor, #9 AWG meter wire.
    Rob
  5. #5
    Join Date
    Jan 2008
    New York City
    Posts
    407
    Quote Originally Posted by infinity View Post
    You are correct!!!
  6. #6
    Join Date
    Jun 2003
    Posts
    9,045
    Thank you, another good day. I've learned something new.
    Tom
    TBLO
  7. #7
    Join Date
    Dec 2007
    NE Nebraska
    Posts
    34,300
    If the meter is owned and maintained by the POCO they likely have their own specifications on how it is to be done. All of them around here install their own CT and meter equipment. Contractor may at times set a cabinet that they provide, but they do the rest.
  8. #8
    Join Date
    Jan 2008
    Columbus, OH
    Posts
    657
    I think I know what you're talking about.... I've seen them use a cable and the insulation actually had AEP written on, among other things, and it wasn't in conduit at all. Came down the pole and to a drip loop and open and down into the top of the meter pan/box.
  9. #9
    Join Date
    Jan 2008
    New York City
    Posts
    407
    Usually I use EMT conduit but a Con ed inspector requires me to use a rigid pipe.
    I have been involved in at least 20 diferent buildings and we always use emt.
    Now the reason for it is because he says some body can easily open a coupling and cut one of the wires and change or alter the meter reading .
    The funny part is he says that I have to use rigid but I can use compression fittings . What is the difference ?
  10. #10
    Join Date
    Jul 2003
    New Jersey
    Posts
    24,174
    Their own spec for some things says EMT may be used, note D:
    http://www.coned.com/es/specs/electr...Spec%20195.pdf
    Rob
Posting Permissions
  • You may not post replies
  • You may not edit your posts
