Closed Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: T8 bulbs working on T12 ballast
  1. #1
    Join Date
    May 2005
    Ft.Worth, T.X.
    Posts
    425
    I went to a job today and on all their F40T12 fixtures where 1 or 2 of the 4 bulbs had burned out they had replaced them with T8 bulbs and they were all working. Why would a T8 bulb work on a F40T12 ballast, and will the T8 bulbs burn out faster? I just always assumed T8 bulbs would not work on a T12 ballast, but aparently they do.
  2. #2
    Join Date
    Jul 2008
    Iowa
    Posts
    447
    If you run a t8 bulb on a t12 ballast you will have premature bulb life as the t12 ballast will over "tax" the bulb. If you run it vice versa and have a t8 ballast running a t12 bulb you will have premature ballast life as the t12 bulb takes more to run and will over work the ballast.
  3. #3
    Join Date
    May 2005
    Ft.Worth, T.X.
    Posts
    425
    Quote Originally Posted by fireryan View Post
    Thank you for the info. Do you happen to have any link to a site I could print some manufaturers data stating what you just told me. i wanted to show these customers something "official" looking. They seem to think since they are working like they are that there is no problem.
  4. #4
    Join Date
    May 2005
    Richmond, Virginia
    Posts
    21,838
    Quote Originally Posted by GG View Post
    Just point them to this thread.
    After all, what's more official than the Mike Holt forum?
    Code references based on 2005 NEC
    Larry B. Fine
    Master Electrician
    Electrical Contractor
    Richmond, VA
  5. #5
    Join Date
    Aug 2010
    Ma
    Posts
    1,277
    GG
    Here's a link for sylvania ballast info guide.http://assets.sylvania.com/assets/do...968ee0a7cb.pdf
  6. #6
    Join Date
    May 2010
    Posts
    604
    Ok. Let's keep in mind one thing. Unlike incandescent lamps where the filament is the load, the fluorescents and HID lamps are actually a conductor, where the gas gets ignited by the amperage created by the load we call ballast. Both the T12 and T8 use same kinda gases, but the t12 need higher amperage to be pushed thru (and voltage) to ignite the gas. So a T8 should definitely work on a t12 ballast(as the t12 use higher voltage and amperage to ignite the gas). Would they have a premature life? Hard to say, if the gas stays intact and doesn't leak, no. Remember, the lamps is a conductor here, so look at it as a piece of #12 wire.
  7. #7
    Join Date
    Apr 2006
    S.C.
    Posts
    554
    Quote Originally Posted by LEO2854 View Post
    GG
    Bad link
    RC
    It's my name going on that drawing, not yours. If what you want ain't right, it ain't going on the drawings!
  8. #8
    Join Date
    Aug 2010
    Saint Joe, Arkansas
    Posts
    124
    Quote Originally Posted by Strife View Post
    Not quite accurate. The lamps and ballast are a system designed to work with thier complimentary parts. T8 lamp life does decrease when run on a T12 ballast. We used to catch retrofit cheaters by looking for the premature blackening on the ends of the T8 lamps.
  9. #9
    Join Date
    Aug 2009
    Central NC
    Posts
    1,350
    Quote Originally Posted by BullsnPyrs View Post
    Speaking of such, how many of you have done retrofits? Do the kits work well and fit a wide range of fixtures? I'm sure I'll get a call for one sometime soon.
    Yes, I'll be happy to do a first class job for less than anyone else and take a dollar a week for 10 years.
  10. #10
    Join Date
    Aug 2010
    Saint Joe, Arkansas
    Posts
    124
    Yes, if you pay attention to fixture depths.
Closed Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
