Results 1 to 6 of 6
Thread: plugs on SO cords
  1. #1
    Join Date
    Dec 2010
    Warrensburg Missouri
    Posts
    17
    plugs on SO cords
    Is there a code or generally excepted practice for wiring electrical plugs on SO type cords? Other than the standard 110 power cords. For example a 3 phase 4 wire plug. Is there any relationship between the wire colors (red, black, white), the X,Y,Z terminals on the plug and phases 1, 2, 3?
  2. #2
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    33,180
    There are excepted methods but nothing that insists that you wire it a particular way. The key is the egc and the neutral if any exist.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  3. #3
    Join Date
    Mar 2006
    Tampa Florida
    Posts
    8,009
    Would be nice but is not even a rule for black red blue. Could be issue if rotation is issue. Ran into this when i wired an ice cream wearhouse that had 2 dozen truck docks. All i could do is make sure all of mine were same for Tampa location. When they go to another terminal could be issues.
  4. #4
    Join Date
    Dec 2010
    Posts
    17
    Quote Originally Posted by Dennis Alwon View Post
    The closest i came was UL 498. But nothing definite.
  5. #5
    Join Date
    Dec 2010
    Tennessee NEC:2008
    Posts
    4,617
    Quote Originally Posted by hoyerr View Post
    As Dennis and Jim said, it would be nice. If one were to wire everything that the cord/plug would be connected to then you could follow a standard, but that's not always the case. It depends on if the receptacles were wired the same way, then sometimes you are plugging into a female on another cord that might not be wired the same or even have the same color wires. I have seen people try to wire a male plug then a female and forget that looking face on to the plug is not the same as the plugs facing each other. You just have to be prepared to take the plug apart and swapping 2 of the wires if using a 3 ph motor.
  6. #6
    Join Date
    Sep 2006
    My Old Kentucky Home
    Posts
    150
    We use to have a real problem with portable equiptment and the wild leg getting into the control circuit until we put in some small transformers in each panel. Yea I know what everybody must be thinking but things were like that well before I got there.
    The best way for evil to prevail, is for good to do nothing.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
