Results 1 to 3 of 3
Thread: Pool Bonding
  1. #1
    Join Date
    Mar 2005
    Posts
    198
    Pool Bonding
    I have a upcoming pool projects and would like to make sure my bonding confirms to the 08 code. Walls and floor of the pool are a sprayed on concrete, rebar is set and tied together, using a listed clamp a piece of #8 copper is clamped to rebar and brought to the deck area. All forming shells will have a #8 from lug to individual listed clamps on the rebar in the walls of the pool. Pool deck will be a concrete pour, stubbed out piece of #8 lands on one piece of rebar in the deck, all rebar is tied together with tie wire. At various locations bonding jumpers will be brought to handrail clamps, diving board bolts, ladder, and basket ball clamps, additionaly one piece of # 8 will be taken to the pool equipment room for equipment bonding. Will I also need to encircle the pool perimeter with a #8 clamped in 4 places, since the pool deck contains rebar?
  2. #2
    Quote Originally Posted by eds View Post
    Make sure the number 8 is solid not stranded
    It depends on what the meaning of "is" is.
  3. #3
    Join Date
    Mar 2006
    SW Florida
    Posts
    2,558
    the #8 circle is only used on sand based paver decks. The rebare or wire mesh reiforcing is used in concrete decks.
    Unlimited Electric Contractor/Standard Electric Inspector/Traffic Signal Inspector/Highway Lighting and Level One Traffic Signal Installer.
    I know you believe that you understand what you think I said but I'm sure you realize that what you heard is not what I meant.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
