NEC 110.26 Spaces About Electrical Equipment
mdkallas
Missoula, MT
Hello,
How does NEC 110.26 apply to a 460V electrical panel inside of a chiller unit? The chiller unit includes a main power switch located outside the unit that allows a techician to the power feeding the panel inside the unit.
Thank you,
Mike
mdkallas
Missoula, MT
I guess this leads to another question. How would a compressor located in front of the panel influence which condition the clearance space falls under? The compressor is obviously grounded, but it doesn't seem to fit the description of "concrete, brick, or tile walls".
Thanks
Carultch
Massachusetts
Thanks
If it is any conductive material that isn't intentionally energized, it is condition 2.
kwired
Electron manager
NE Nebraska
If this is all items within a listed assembly, NEC doesn't apply, whatever the listing standards are applies to when it was manufactured.
Control panel on side of a chiller - anything that is not a part of that chiller in front of the control panel should have 110.26 apply to it though.
infinity
New Jersey
Journeyman Electrician
I agree a package unit does not fall under the NEC.
