Results 1 to 8 of 8
Thread: Distance from gas meter
  1. #1
    Join Date
    May 2005
    Ft.Worth, T.X.
    Posts
    425
    I looked at a job today and the existing residential meter base is sitting diretcly above the gas meter. Isnt it required to be 5' from the gas meter?
  2. #2
    Join Date
    Oct 2006
    Posts
    3,293
    That is a Utility co. standard, here "PG&E" wants 36" from the two.
  3. #3
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,892
    The requirement used to be 3' from a/c or heat pumps. I heard that locally that requirement is gone. I bet the utility would say something about the gas meter under their meter.
    They say I shot a man named Gray and took his wife to Italy
    She inherited a million bucks and when she died it came to me
    I can't help it if I'm lucky
  4. #4
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,772
    As far as I know, the NEC has no requirement OTHER THAN, not "directly over". 110.26 would make that a violation: (3) Height of Working Space. The work space shall be clear and extend from the grade, floor, or platform
    At my age, I'm accustomed to restaurants asking me to pay in advance, but now my bank has started sending me their calendar one month at a time.
  5. #5
    Join Date
    Dec 2006
    Chapel Hill, NC
    Posts
    32,892
    Quote Originally Posted by augie47 View Post
    Gus, does that refer to meters which are generally the poco's.
  6. #6
    Join Date
    Jul 2004
    Louisville, Kentucky
    Posts
    2,139
    Quote Originally Posted by GG View Post
    In my area the POCO requires 3' minimum from the supply side of gas meter.
    Norb
    My Boss is a Tyrant and my Employee is an Idiot.
  7. #7
    Join Date
    Jul 2005
    Tennessee
    Posts
    15,772
    Quote Originally Posted by Dennis Alwon View Post
    nope... not in this area anyway.,.,.. caught me as I said in a "dumb statement" thread.."watch me".... I just rejected an outside panel over a gas meter and my mind was there instead of on the thread as it should be.... sometimes it takes side trips..
  8. #8
    Join Date
    May 2005
    Ft.Worth, T.X.
    Posts
    425
    Well the owner said the city inspector came out and saw the meter base directly above the gas meter and said "its fine". I can also reach up and touch the service conductors, if I wanted to. I guess thats fine as well? #8 wire running to a ground rod secured with a romex connector. I guess thats also fine. I think this owner is trying to hose me.
    I told him unless we do it right then Im not interested what the inspector claims to have said was "ok". Meter base is also over 7' off the ground. Its a new GE indoor panel and looks like a handyman put the panel in for cheap and now the owner wants to flip the house and wants it done cheap. Good luck.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
